After an a object is formed through direct laser sintering, as a post-processing procedure the object is sent for hot-isostatic pressing, In hot isostatic pressing the sintered object is placed in a mold and then pressure and heat are applied.
I was wondering what would go wrong if the bare object without the mold was made to undergo pressing? Remember the sintered object already has a shape acquired during sintering so it may need a mold to get a specific shape during pressing. My assumption- In hot isostatic pressing the object might get softened and hence deformed due to heat and thus the requirement of a mold to keep the object firm. Is this assumption true??
And apart from deformation are there any other undesirable effects caused to the un-molded object during hot isostatic pressing?
$\begingroup$ If the mold is not there to provide the final shape - what shape will you get after pressing? $\endgroup$– Solar MikeFeb 19, 2020 at 15:23
$\begingroup$ @SolarMike Oh I forgot to add something in the question. Ill edit the question. $\endgroup$– SomannaFeb 19, 2020 at 18:40
Add a comment
