I’m trying to create the following extrude.
I have created a crankshaft based on the following sketch:
I then removed material as follows, which is placed on the rear surface of the shaft.
The material is removed successfully, however my final result has a thick extruding circle around the top of the crankshaft.
What am I doing wrong ?
