The Diagram below shows a lap joint where two plates are held together by a bolt. The applied force (F) is $42~\text{kN}$ and the shear stress is $593~\frac{\text{N}}{\text{m}^2}$ Assuming that the joint will be held together by a standard metric bolt, determine the minimum diameter permissible and identify the standard bolt diameter that will need to be used.
This is my answer is this correct?
$$\sum f_x=0$$
$$V = \frac{p}{1} = \frac{42}{1} = 42kN$$
$$\text{shear Stress} = 593N/m^2$$
$$593^2 = 351.649 Kn$$
$$ \frac {42000}{351.649} = 119$$
$$ a = \frac{pi}{4} D^2$$
$$D = \sqrt\frac{4A}{pi}$$
$$D = \sqrt\frac{(4) (119)}{pi}$$
$$ = 12.309$$
Is this the correct answer, and the correct way to complete this question?
