-1
Why inner radius of the housing washer and shaft washer is different in thrust bearing? I checked on SKF's website dimensions of a thrust bearing. The inner radius of the housing washer is different than the shaft washer inner radius. Can any you tell why is that?
  • $\begingroup$ So that the bearing works as a bearing. $\endgroup$
    Feb 6 '20 at 9:46
  • $\begingroup$ Can you elaborate? $\endgroup$ Feb 6 '20 at 9:50
  • $\begingroup$ Provide an image explaining exactly what you are discussing. $\endgroup$
    Feb 6 '20 at 9:52
The race with a tighter inner diameter is meant to press onto a shaft and transmit the thrust load from the shaft into the bearing elements. The housing race has a looser bore and is meant to clear the shaft so it does not accept any thrust from the shaft, this race is typically a press into your housing.
