I'm trying to figure out a correlation between correct feed rating and the feed force.
Can a specific feed force be declared to create the correct feed rate per material per tool speed?
  • $\begingroup$ A constant force means thats you must have a changing speed dv/dt which is not what you want in a drilling process! $\endgroup$ Feb 6 '20 at 4:40
  • $\begingroup$ Let's suppose that we could somehow keep the speed constant. Would the constant feed force still be irrelevant to constant feed rate? $\endgroup$
    – ceremcem
    Feb 7 '20 at 1:32
