Will epoxy resin dissolve a silicone spatula, cake icing spatula? Will it work well enough to get the job done without contaminating the resin?
$\begingroup$ make a test batch and find out. $\endgroup$ – Solar Mike Feb 5 '20 at 12:40
$\begingroup$ Dude, can you pay for that or what? $\endgroup$ – Andyz Smith Feb 5 '20 at 12:56
$\begingroup$ You can buy the resin and a spatula and test to your heart's content. $\endgroup$ – Solar Mike Feb 5 '20 at 12:58
$\begingroup$ What brand of resin are you using? Two part resin is compatible with most materials, haven't had any issues mixing it in solo cups. I think some applicators are even silicone to help evenly spread the pour. $\endgroup$ – jko Feb 5 '20 at 16:57
$\begingroup$ The spatula won't be harmed. Nor will it do anything well. If you are trying to make a nice fillet, use an suitable old lightbulb for big fillets, or a mellon baller for smaller ones. They sell sets of filleting tools as well. There is an industry standard yellow plastic epoxy spreader that works well and can be cut easily for fillets. Hardened epoxy peels right off. $\endgroup$ – Phil Sweet Feb 6 '20 at 2:19
Silicone molds are often used for epoxy resin casting, so I don't see any problems.
