-1
The other day, some restauraunts in the union were closed "due to steam outage." I had seen the venting of course, but had thought little about why the school has a steam system. As best I can find, steam is usually used for heat distribution from a central heat plant; more efficient, etc. But the average yearly low temperature here is 57 degrees. What purpose does the system serve?
Steam networks are used for heating (there are still heaters in use on the gulf coast), creating hot water, and any other energy loads a university might need. I suspect that the restaurants in question didn't have hot water.
| improve this answer | |
