-1
Consider this image of a loop shaping design:
here which is the bandwidth of the system? I have a doubt because until now I have considered as bandwidth to the system the one of the complementary sensitivity function, but I heard someone sayong that it is not a good measure for the bandwidth, so it is better to consider as bandwidth the one of the sensitivity function.
Can somebody clarify this?
There are many definitions of bandwidth. Typically it is determined from the open loop transfer function and not from the sensitivity or complementary sensitivity functions.
Assuming a SISO feedback loop, with plant $P$ and controller $C$, a common definition of bandwidth is the 0 dB crossover frequency of the open loop transfer function $PC$. Assuming that the sensitivity can be written as $\frac{1}{1 + PC}$ this is also (roughly) the frequency where the sensitivity peaks.
