There is a heat storage tank that is directly loaded from the top and the heat is also taken from the top. The colder water from the heating circuit return flow enters the heat storage tank at the bottom. This creates a layered water temperature in the heat storage tank.
There are three temperature sensors inside the heat storage tank.
Is it possible to calculate the stored energy via these three temperature sensors?
Edit - Calculation Attempt according to Solar Mike:
$V_{storage} = 1000\ l = 1\ m^3$
$t_{top} = 82\ ^\circ C$, $t_{middle} = 70\ ^\circ C$, $t_{bottom} = 55\ ^\circ C$
$t_{average} = \frac{82+70+55}{3} = 69\ ^\circ C$
$Q = M \cdot c_{H_2O} \cdot \Delta T = V_{H_2O} \cdot p_{H_2O} \cdot c_{H_2O} \cdot \Delta T $
$\ \ \ = 1\ m^3 \cdot 1.163\ \frac{kWh}{m^3K} \cdot (69\ ^\circ C - 20\ ^\circ C) = 56.987\ kWh$
Does this calculation give me a fairly correct value for the stored energy?
