**Background **
I'm struggling finding how to calculate the pressure that occurs within my system and then once calculated I need to reduce that pressure.
My system
I have a 1 inch copper pipe that is 9 inches long. Inside that pipe I have a 3/4" heating element designed for heating liquids with heat transfer oil surrounding it and threaded into the 1 inch pipe. My desired temperature is about 450 degrees F. The system is a closed system and the fluid isn't moving so of course as I heat the oil up, pressure will increase.
Questions
Will soldered copper connections handle this pressure? Is there a way to calculate the maximum pressure at 450 degrees F? I believe once I know that, a pressure relief valve should help with this problem?
Thanks for the help and feel free to ask clarification questions.
