-1
I am new in learning C++. I have used this code to show an image, but there is an error that I do not understand!
This is the simple code:
include iostream
include conio.h
include opencv2/core.hpp
include opencv2/highgui.hpp
include opencv2/opencv.hpp
include opencv2/imgproc.hpp
using namespace cv;
using namespace std;
int main()
{ std::cout << "Hello World!\n";
Mat img = imread("lena.jpg");
namedWindow("input image", WINDOW_NORMAL);
imshow("image", img);
waitKey(0);
return 0;
when I run, system.cpp will open and "Exception Unhandled" will be apear!!! here is a picture of that, may you help please!
    $\begingroup$ I'm voting to close this question as off-topic because it belongs on a software or coding stack. $\endgroup$ – Solar Mike Jan 17 at 10:35
  • $\begingroup$ Welcome to Engineering! This question seems more relevant to Stack Overflow. $\endgroup$ – Wasabi Jan 18 at 0:50
I have found the solution! I did these three steps and everything is ok now!
1) I restored my system through: start/create a restore point/ system protection/ system restore/next/next...
2) I work with visual studio 2019 and I have two kind of libraries: v14 and v15, so I add both directories into the libraries direction
3) copy my code to new project!!
after these steps, the code works properly :D
| improve this answer | |
  • $\begingroup$ If you accept this answer to close out the question, that would be great! $\endgroup$ – J. Ari Jan 17 at 16:20
