I wish to rotate a short cylinder (thick disc) by 150 degrees. I chosed to use a double torsion spring for this (as the picture below). The picture shows only one side.
I wonder if the above design (cylinder and spring) would actually work. I have no knowledge in springs.. Do you have alternative suggestions for the design of cylinder and springenter image description here?
Yes. To reduce wear, material fatigue, and strength needed to turn it, you should use a couple coils of the spring, leave enough play so it won't seize when tensioned, and obviously the disc needs to sit on an independent bearing/bushing/hinge to turn, spring only providing tension - it's no replacement for a bearing.
