Recently I have seen a question as follows:
Dimension of the hole is $50 +.02/-.00$ mm and shaft is $50 +.02/-.00$ mm.The minimum clearance is?
My answer is .00 but the correct answer as per the website is -.02
Where am I going wrong?
Please help me.
The minimum clearance occurs when the largest possible shaft meets the smallest possible hole. That would be in this case a shaft of $50.02 mm$ in a hole of $50.00 mm$. The difference between the two is the $-0.02 mm$ from the solution you found.
    $\begingroup$ That would be an interference fit... $\endgroup$
    Jan 6, 2020 at 18:43
