I am looking at a control system which has an unstable pole in the process. The transfer functions of process and controller are the following:
G = 10/((s+10)*(s-1));
K1 = 4*(s+1)/s;
where G is the process and K1 is the controller. I have found with the Routh Criterion that the closed loop is stable for $K>1.125$ and so I have chose the value 4 since it gives good performances. Now, when I plot the root locus of the closed loop:
T1 = K1*G/(1+K1*G)
figure;
rlocus(T1)
I get the following:
What I don't undestand is from where the zero that cancels the unstable pole comes from, since the closed loop transfer function is:
$\frac{(40(s + 1))}{(40 - 10s + 40s + 9s^2 + s^3)}$
can somebody help me?
