Looking at a part like this LM2596
It is rated for 3Amps with a voltage range from 3.3-12 volts.
Does that mean that this voltage regulator will only output a maximum of 3amps?
That is an oversimplification.
From the data sheet http://www.ti.com/lit/ds/symlink/lm2596.pdf there are two relevant features, internal over-temperature protection and a maximum current limiter (Typical value 4.5A, minimum 3.6A).
The bottom line is that trying to get more than 3A continuous current from the regulator will probably not end well.
|improve this answer|||||
