I want to attach a 12 toothed spur gear with a bore diameter of 6mm onto the shaft of this motor (6mm diameter). How would I go about doing this? From what I see, the shaft is smooth so is my only option to find a gear with a set screw? Or is it sufficient to attach a gear with no set screw and simply rely on the friction of the bore? The torques will be low.
Are there any websites that one would recommend for finding gears like this? I'm finding it impossible to find gears with a module of 1.0, bore diam. of 6mm, and a thickness of less than 20mm to fit onto the shaft.
Any help would be greatly appreciated.
