Belleville disc springs are usually spec'd with a free height, loaded height, and loaded force. From this information you can calculate the average spring rate of a belleville spring. However, what I would like to know if if the force is actually linear (or nearly linear).
I assume it is not, but don't know what curve the force might follow. Is there an equation that can predict the force-curve (plot of force versus height) of a belleville spring given ID, OD, free height, and thickness?
  • $\begingroup$ From anecdotal experience, the rate gradually rises as you compress it $\endgroup$ – Jonathan R Swift Dec 4 '19 at 15:46
The curve is not linear.
$s = $ actual deflection (mm)
$h_o = $ total possible deflection (mm)
$F = $ actual load (N)
$F_c = $ designed limit load (N)
Here you can see the original archive with the ploted graph from one industry (I usualy use this material for reference about these type of spring).
I don't know the exact formula. But the reasoning should be (this is my guess):
  • From 0% Force to ~70% force should be affected mostly by the compression between the inner diameter and outer diameter.
  • From ~70% Force to 100% should be affected mostly by bending.
