This confusion arise because my teacher says that volume does not change under tensile/compressive stress within the elastic limit of the material ( consider metal here). But as far as I can see via applying Poisson's ratio it does ( otherwise lateral strain would be proportional to square root of longitudinal strain). So does the volume chaneg under tensile stress ? What might be the molecular basis of such?
I defined a quantity (cause it was simple to calculate) $ \frac {\Delta A}{A}$ and then found that
via **Poisson's ratio
$$ \frac {\Delta A}{A} = \alpha \epsilon _{lon}( \alpha \epsilon _{lon} +2)$$
whereas the one derived via assuming the volume to be constant (i.e., $AL = A_0 L_0$) was $$ \frac {\Delta A}{A} = \frac {\epsilon _{lon}}{\epsilon _{lon} +1}$$
Here $ \alpha = \frac {\epsilon_{lat}}{\epsilon_{lon}}$
  • $\begingroup$ If the length changes under compression for a bar then will the diameter increase? $\endgroup$
    Nov 23, 2019 at 16:41
  • $\begingroup$ @Solar yes it will (Poisson's ratio) $\endgroup$
    – user23622
    Nov 23, 2019 at 16:43
  • $\begingroup$ May I see your equations ? $\endgroup$
    – user14407
    Nov 23, 2019 at 16:44
    $\begingroup$ In fact, Poisson thought this was correct, and therefore his ratio was 0.5 for all materials. And one of his colleagues Cagniard-Latour measured this incorrect value for brass, and so "proved" Poisson was right. Well, everybody makes mistakes sometimes - including your teacher :) $\endgroup$
    – alephzero
    Nov 23, 2019 at 18:36
    $\begingroup$ @SolarMike "the net volume change is????" - either positive, negative, or zero. I'm not sure where you are trying to get to here. $\endgroup$
    – alephzero
    Nov 23, 2019 at 18:40
Yes, the volume changes.
The relative change of volume $ΔV/V $of a cube due to the stretch of the material :
Using $V = L^3$ and
$V + \Delta V = (L + \Delta L)\left(L + \Delta L'\right)^2$:
:$\frac{\Delta V}{V} = \left(1 + \frac{\Delta L}{L} \right)\left(1 + \frac{\Delta L'}{L} \right)^2 - 1$
Using the above derived relationship between $\Delta L$ and $\Delta L'$:
:$\frac {\Delta V} {V} = \left(1+\frac{\Delta L}{L} \right)^{1-2\nu} - 1$
and for very small values of $\Delta L \ and \ \Delta L'$, the first-order approximation yields:
$$\frac {\Delta V} {V} \approx (1-2\nu)\frac{\Delta L}{L}$$
For isotropic materials, we can use Lamé parameters
$$ \frac{1}{2} - \frac{E}{6K}$$
where K is bulk modulus and E is elastic modulus or Young's modulus. wikipedia link
