I have a simulation model of a cylindrical hot water storage tank. The heat loss is determined by the surface area and the heat transfer coefficient.
A configuration of the storage tank with 900 liters was validated with a real scenario.
Now I would like to test how the scenario changes when the storage tank gets bigger. Thereby my surface becomes bigger, but I don't know if the heat transfer coefficient changes as well.
Does a larger storage tank usually improve the insulation so that the heat transfer coefficient changes?
