Air conditioner device installed near the ceiling
Almost all air conditioners (AC) are installed on top. For house small office use, will be like the picture. For office with central air conditioner, the blowing come from the ceiling through duct. But however, still there are few occasion where the air conditioner is installed near the floor, like once I saw in a historical cathedral church, due to esthetic's consideration.
My question, is any thermodynamic reason so almost all air conditioners are installed on top? If any, what is that?
  • $\begingroup$ The floor has tables, cupboards chairs etc - the ceiling does not allowing good airflow. $\endgroup$ – Solar Mike Nov 11 '19 at 4:40
  • $\begingroup$ Seems the explanation from Sam Farjamirad below is more make sense, due to density. We know that the heated hear can leave balloon up. $\endgroup$ – AirCraft Lover Nov 12 '19 at 0:23
The cold air has a higher density so it always settles down, by installing the AC on top, the cold air can interact faster with hotter air, so the cooling process is much faster.
If you install the AC on the floor, the cold air, doesn't naturally travel upward, and even if it does, thanks to the density difference and the air flow of the AC, it then, would be less desirable for human being think about cold feet and hot upper body!
Usually the heat is coming from the outside not the floor, windows for example, they pass the radiation, and simplify the conduction so the heat rate transfer is higher where the windows are installed. In a ten feet high room, an AC should be installed at 8 feet high, slightly above the windows, so the cold air can interacte faster with the hotter air.
There is also a technical issue here, duo to condensation you have to accommodate an extra duct to redirect the water to somewhere else, if you level the AC with floor then you need a pump to let the water flow, however by installing the AC at the recommended height, the gravity does the trick.
    $\begingroup$ Similarly, heaters tend to mounted near the floor. $\endgroup$ – Eric S Nov 11 '19 at 22:39
