Suppose I have a heat generator with a connected heat storage tank. If the heat generator remains the same and the heat storage tank is dimensioned larger, the running time of the heat generator increases due to the higher storage losses. Why is this so?
Normally, the surface with exponent 2 and the volume increases with exponent 3 - should the heat storage tank not have fewer losses?
