I want to repair an outdoor lamp (see images below) however I can't get the glass container open. The methods I found on the internet are based on glue removers or based on heat but I'm not sure this will damage the print inside, as this is what I try to repair. Note that I think it is glued, however if this is not the case please let me know.
What I tried so far:
- Wringing it with a screwdriver (the image on the side shows a clear 'edge' on top, however I can't get really deep
- Applying moderate heat
Goals:
- No damage the the circuit board inside
- No damage to the glass container (if unavoidable I prefer breaking the bottom part which does not contain LED's)
- Usage of common house tools or tools that are fairly cheap to get (and safe for me to use on a kitchen table)
Images:
Bottom view
Top view
Side view
Related: Loosening glass that is vacuum
