A lifting device consists of an electric motor, a gearbox and a drum with a cable for lifting a mass.
The speed after the initial acceleration is $v=0.5\,\text{m/s}$.
The gear efficiency $\eta=0.7$
Maximum motor torque is $T=15 \, \text{Nm}$
Motor inertia $J_m=0.005 \, \text{kgm}^2$
Drum diameter $d = 0.5 \, \text{m}$
Motor rotating speed after initial acceleration $n=2600\, \text{rpm}$
The inertia of the drum $J_L$ is considered small and thus neglected.
I want to Calculate how much time it takes for the motor to accelerate the mass $m=510 \,\text{kg}$ from standstill upwards to the given speed. Assume constant acceleration.
I know applying Newton's second law that:
$$F-mg=ma$$ and then we get the acceleration
$$a=\frac{F-mg}{m}$$ and the speed v
$$v=at$$ so $$t=\frac{mv}{F-mg}$$
The motor rotates the geared system $\omega_M$ and the geared system rotates the drum $\omega_L$.
The mass $m$ causes the torque $T_L=mgr$ on the rope drum. So the power of the load is $P_L=T_L\omega_L$. And therefore $\eta P_m=P_L$ and there I get the $\omega_L$ when $$\omega_L=\frac{\eta\, T_m\, \omega_m}{T_L}$$
But how do I get force $F$ so I can calculate the time or is there better way to do this?
Or can I calculate the acceleration $a = \frac{T}{J_{motor}}$
