I am a graduate student trying to sharpen the direct stiffness method skills. However, I am stuck at the beginning.
The problem is given in the image.
Can someone help me to write down all the nodal and member forces with equations ?
Sign up to join this communityBecause the specific value are not given, I will give a general overview of the method. When applying the direct stiffness method for trusses, the following steps must be used:
Find the local stiffness matrix for each individual element as following:
$\begin{bmatrix}AE/L & 0 & -AE/L & 0 \\0 & 0 & 0 & 0\\-AE/L & 0 & AE/L & 0 \\0 & 0 &0 &0\end{bmatrix}$
You also need a beta matrix in order to convert the local coordinate system into global coordinates.
$\beta = \begin{bmatrix} cos\theta & sin\theta & 0 & 0 \\-sin\theta & cos\theta & 0 & 0\\0 & 0 & cos\theta & sin\theta \\0 & 0 &-sin\theta & cos\theta\end{bmatrix}$
Then, $[\beta]^T[k_l][\beta] = [k_g]$
Complete the same process for all matrices and then assemble global matrices to create the system matrix [K]. Apply boundary conditions for the problem.
Then solve for the nodal displacements by using the equation, $[K]^{-1}[F] = [U]$
Where F is the forces at the joints and U is the nodal displacements.
Expand [U] into elemental displacements $[U_{1,2,3}]$
Multiply each by their own original beta matrices in order to produce $[\delta_{1,2,3}]$
Multiply each original stiffness matrices by their delta values like so: $[k_l][\delta_{1,2,3}] = [F_{e 1,2,3,}]$
This will produce the elemental forces.
Let's call the length of square truss members L then the diagonal angle is 45 degrees (let me know if the diagram is not to scale).
$\Sigma M_1= -LF_{4,2}+ LF_{4,3}=0 \quad F_{4,2}=F_{4,3} \ pointing\ left \\ F_{3}= -F \ pointing \ right \quad member_{ 3,4}= \ in\ tension\quad R_3= F \ pionting\ left$
$\Sigma F_{v1}=0 \quad F_{v1}= F\ pointing\ down \ R_{v1}=F\ pointing\ up $
$ \Sigma F_{h1}=0 \quad F_{h1}= F\ pointing \ left \quad R_{h1}=F\ pointing\ right \\ member \ 1,4 \ in \ compression \\ F_{1,4}= \sqrt{2}*F $
Members 1,2 and 2,4 are zero stressed.
