I'm pursuing Mechanical Engineering and i need to learn AUTOCAD, is there any site where i can download free video tutorials
If you are willing to pay monthly (first month free) then there are AutoCAD tutorials on LinkedIn Learning
If you don't have to use AutoCAD then Fusion360 is a very popular and equally capable programme that engineers and designers use and its free to use for startups and hobbyists and presumably students. As its cloud based the online support and comprehensive tutorials are all available online.
8
    $\begingroup$ In fact i would go as far as to say that a mechanical engineer should not go out and learn AutoCAD at all. But more likely Solidworks, NX, Creo, Inventor, Fusion 360 etc . All of which are free for a suitable student. It is only Civil engineering that still uses AutoCAD. For mechanical engineering AutoCAD is pretty much obsolete... Although nice to have. $\endgroup$
    – joojaa
    Oct 20, 2019 at 6:25
    $\begingroup$ @joojaa not that your point is inaccurate, but it makes civil people sound dumb and old fashioned. :( In reality, it's because civil projects tend to have so many more details that are only used once (project unique) where making standardized parts are generally a lot harder to implement than mechanical where you generally expect to make the same parts more than once. Just think of McDonalds, no two McDonalds are exactly the same, but they only use a limited selection of brands of fryers across all stores. ACad is great for drafting, so it cuts computer work hrs if all jobs are unique. $\endgroup$
    – Isa
    Oct 22, 2019 at 17:28
    $\begingroup$ @Isa it has more to do with the way the work is spread around. Very many very small operators who collectively dont have enough clout to specify how their cad should work. Anything you can draft in autocad in an hour you can do in other cads in an hour. However the other cads have a better change management. OTOH civil engineers have a better management databases due to having skipped the better cad. I do a lot of modeling and i never do the same thing 2 times $\endgroup$
    – joojaa
    Oct 22, 2019 at 17:56
    $\begingroup$ The main difference is not how many times a thing is done. But who it is done for mechanical engineers model things to help themselves, civil engineers see it quite often as a method to satisfy code. So mechanical engineers treat their models with more respect, since the same model gives them the FEM calculation, Manufacturing paths, maintenance plans.... Remember we do not have armies of construction workers who need to be managed, or fix/make trouble $\endgroup$
    – joojaa
    Oct 22, 2019 at 18:03
  • $\begingroup$ @joojaa I would go on to add that most mechanical and electrical engineers that deal with buildings, highways, bridges, probably tend to use AutoCAD or one of its flavours a lot. Namely because because its usually a lot of HVAC, Plumbling, Electrical Runs, etc. A lot of information that does not need to be 3D model or need FEM work. Furthermore, AutoCAD tends to be very popular as it has been around for a long time and has a large market share that other quite capable CAD prgs are still trying to get a significant market share. $\endgroup$
    – Forward Ed
    Feb 6, 2022 at 13:25
You can find many free courses if you search for it on YouTube.
Here is one example: AutoCad tutorials
