I have a scenario where a valve q_in(t) is pumping water into a tank of height h(t) and area A, which is then pumped out by a second valve q_out(t) that has a resistance to water flow R.
I got this transfer function:
$ \frac{H(s)}{Q_i(s)} = \frac{R}{A R s + 1} $
Where R= 1.5m(m^3/min) and A= 2m^2
I would be grateful if someone could tell me how to get the value of Rs so I can plot the transfer function in Labview!
15
  • $\begingroup$ Do you mean $ \frac{H(s)}{Q_i(s)} = \frac{R}{A R s + 1} $? If so, please edit your question with the appropriate parentheses, or replace your relevant text-math with $ \frac{H(s)}{Q_i(s)} = \frac{R}{A R s + 1} $. And you ask for the value of "Rs" -- do you mean "R times s", where s is the Heavyside operator? $\endgroup$ – TimWescott Oct 14 '19 at 16:43
  • $\begingroup$ Yes sorry, R times s is what I want! I will change the equation now! $\endgroup$ – MelanieW403 Oct 14 '19 at 16:49
  • $\begingroup$ Thanks for your help about the equation! $\endgroup$ – MelanieW403 Oct 14 '19 at 18:22
  • $\begingroup$ If you could tell me how to get R times s so I could plot the values in a graph I would be very grateful. $\endgroup$ – MelanieW403 Oct 14 '19 at 18:24
    $\begingroup$ $s$ is an operator, not a variable per se. A transfer function is a shorthand for a differential equation that describes the behavior of a linear system. You can use a transfer function almost directly to get a frequency response of a system by substituting values into $s$, but to get a response to a signal in the time domain, you need to simulate the system, or solve the inverse Laplace transform of the output signal. This should be a matter of pushing the right buttons in Labview, but I'm not familiar with that program. $\endgroup$ – TimWescott Oct 14 '19 at 18:47
