The biggest unknown you need to determine or guess is the coefficient of rolling friction.
For reference, a coefficient for rolling friction of 0.3 is already very high and is for something like for soft wheels (which deform) on a dirt road (which isn't flat or hard) where it is light enough it won't sink in. Most of the time it should be more like 0.1 to 0.2 with it being lowest on smooth hard surfaces with smooth hard wheels.
A value of 0.3 means rolling on wheels on a horizontal surface takes 30% the force of just lifting it up. Ideally you want it to be zero. At >1 it is easier to just pick the thing up rather than roll. Knowing this definition should help you get a intuitive feel for what the coefficient of friction should be. You will have to estimate or measure this most important value or conservatively guess a worst case.
If measuring rolling friction (by pushing or pulling the scooter to determine the fraction of the weight that must be applied to slowly budge the scooter on a horizontal surface) be aware of drive train losses (i.e. gearbox friction) if it is present and linked to the wheels during the test which can obfuscate the measurement. This should technically be included in drive efficiency term and not the rolling friction coefficient but may be easier to measure it along with rolling friction and just lump it all together as rolling friction. This decreases accuracy in inclined scenarios though where roling friction decreases but drive friction remains constant. If doing a lumped measurement and the gearbox was present but not the motor you can include motor efficiency separately using the drive efficiency term while leaving gearbox friction lumped in with rolling friction.
I laid everything out so you should only need to read it from top to bottom and look backwards for variables, never forward. I also tried to lay it out so hopefully you know where everything is coming from (as long as you have a basic understanding of power, torque, force, and friction...maybe even if you don't).
$ m_{vehicle} = $ mass of vehicle (kg)
$ g = $ acceleration of gravity $ =9.81m/s^2$
$ W_{vehicle} = $ weight of vehicle (N) $ =m_{vehicle}\times g$
$v=$ speed (m/s)
$\mu_{roll}$ = coefficient of rolling friction for wheels
$\theta=$ angle of incline
$ \eta = $ drive efficiency (between 0 and 1 for 0% to 100%). Use 1 if you need output power (or in calculations of required output like torque). Use actual efficiency if you need input power
$ F_{roll} =$ force of rolling friction $=W_{\perp vehicle} \times \mu_{roll}=W_{vehicle}cos(\theta)\times \mu_{roll}$
$ a = $ desired acceleration $(m/s^2)$
$ F_{acceleration} = $ ADDITIONAL force required to accelerate $ =m_{vehicle} \times [a + gsin(\theta)] $
$ r_{wheel} $ = radius of driven wheel (m)
$ \tau_{roll} $ = torque required to overcome rolling friction (i.e. to maintain constant speed)$ = F_{roll} \times r_{wheel}$
$ \tau_{acceleration} = $ ADDITIONAL torque required to accelerate $ =F_{acceleration} \times r_{wheel}$
$ \tau_{total}= $ total torque required to accelerate $=\tau_{roll}+\tau_{acceleration}$
$ P_{continuous} = $ Continuous power to maintain speed $= F_{roll} \times v \times \frac{1}{\eta}$
$ P_{peak} = $ Peak power to accelerate $= [F_{roll} + F_{acceleration}] \times v \times \frac{1}{\eta}$
Speed-dependent losses such as aerodynamic resistance or speed-dependent drive-train losses have been neglected.
