I want to calculate brake torque from indicated torque for motorcycle.
$\begingroup$ What is preventing you from calculating brake torque? $\endgroup$ – Mahendra Gunawardena Oct 12 '19 at 20:41
$\begingroup$ I've never heard the term "brake torque." Brake horsepower comes from the use of a brake to measure torque. $\endgroup$ – Tiger Guy Mar 9 '20 at 15:11
Add a comment
Brake torque usually means torque at the engine crankshaft, while there is no loss of power or toque due to transmission, powertrain or in your case the chain and gearbox.
You would have to subtract those losses if the indicated torque is the wheel torque.
