I did a Civil Engineering course some years ago and from my textbook I had a question on a bending pipe. The purpose of this question is to see if the way that I have calculated this is correct, as my answer is slightly out from the textbook answer.
Feedback will be much appreciated on my calculations?
I have the question below
Chapt 9 - Question 27 Chapt 9 - Question 27 Figure
  • $\begingroup$ @SamFarjamirad I think you are being harsh. I have made an attempt to solve the question, it is in the scans, I just need someone to confirm if I have got this correct, what is wrong with this. It is not off topic as it is about finding Horizontal and Vertical Force on Bending Pipe. You should reconsider this. $\endgroup$ Sep 28, 2019 at 22:03
  • $\begingroup$ @SamFarjamirad I am just wondering if you have properly looked at my scans and see that I have my answer in them? Can you not see that I am getting clarification on what I have is correct. I would think better of you, if you reply, rather than just ignoring me. I have more questions to come and would appreciate the block to be stopped, so I can post them otherwise I will be using another website for posts. $\endgroup$ Sep 29, 2019 at 2:19
  • $\begingroup$ I retracted the 'Close Vote' because I was wrong about the no attempt ... . If you edit the question then maybe you get much more notice. $\endgroup$
    – user14407
    Sep 30, 2019 at 7:31
  • $\begingroup$ @SamFarjamirad It looks like I still can't ask any more questions. $\endgroup$ Oct 2, 2019 at 1:18
  • $\begingroup$ I have no authority to block users here neither any other users, maybe a technical problem I don't know . Please go to 'chat' then ask the moderators to solve the issue. $\endgroup$
    – user14407
    Oct 2, 2019 at 9:15
