I have an .inp file of Ansys that is basically a mesh, that could be imported into Ansys APDL and converting to .cdb file.
But I also have another .IGES file that I should import in the same model and assemble on the first one. How do I do that ?
You could import the .inp file containing your mesh into Ansys Mechanical APDL, then import your .iges as well (through File/Import/IGES or sometimes Archive Model/Read in /prep7 works smoother), give your attributes to the different areas, mesh them, and export the whole model in .cdb.
