I found these symbols in a electronic datasheet.. Are these all logic gates? or another? What does this symbols mean?
  • $\begingroup$ Can you please post the datasheet that your referencing? $\endgroup$ Sep 19, 2019 at 13:32
Yes! The logic gates from a RS485/422. Most likely the signal are level shifted. Below is an except form Low power RS-485/RS-422 transceiver ST485B, ST485C datasheet.
Below is an another similar part. PROFIBUS Compliant 6kV VDE-Reinforced Isolated RS-485 Transceiver ISL32741E. The example circuit is converting signal 3.3V-5V and 5V-3.3V.
