What are the likely causes of a stepped crack up and away from the edge of a lintel? See the diagram below.
1 Answer
Shearing causes stepped cracks and bending causes vertical cracks.
See: "Diagonal Cracks in Brick Walls and Its Measures" or "HeliBar Remedial" where the causes and methods for remediation are explained. Two different causes and means to prevent worsening of the problem.
