This site:(https://www.motioncontroltips.com/faq-what-are-dc-shunt-motors-and-where-are-they-used/ ) explains the speed regulation of DC shunt motor as follows: If the load on the motor is increased, the armature rotation slows and back EMF is reduced, since back EMF is proportional to speed. With less back EMF voltage and a constant supply voltage the net voltage increases. The increase in net voltage results in an increase in armature current. Since torque is proportional to armature current, torque also increases. Finally, this increased torque allows the motor to increase its speed and compensate for the slowdown due to loading. Hence, a DC shunt motor is able to self-regulate its speed, and can be referred to as a constant speed motor.
Considering that torque is inversly related to speed for a DC shunt motor, wouldn't this entire explanation be wrong as the last line mentions increase in speed due to increase in torque ?
