Consider an object of mass M and specific heat C, and initial temperature T1. Let energy is transferred to the object at the rate of W watt. I want to calculate temperature of the object at time t. My understanding is following. At time t, total energy transferred is Wt joules. Using the equation, Q=MCT, where Q=Wt and T is change in temperature, I will get the desired result. Am I correct?
  • $\begingroup$ Yes, you're correct. $\endgroup$ – J. Ari Sep 9 '19 at 18:10
