I use autocad lt 2019. I have turned on LWDISPLAY. When I use match properties on line defined as a layer in model view and copying it to another line the line weight doesn't change of the target line piece. Why is this the case?
  • $\begingroup$ You mention having turned on display of line weights. Have you also confirmed that line weight is turned on in the match properties settings? $\endgroup$ – CableStay Aug 30 '19 at 5:29
