I have to drive several 12V servo motors. So I wanna to get 12V PWM Controller (12V Logic Controller). I have MCU as Atmel SAM3X8E arduino due board. It has 5V PWM outs. Is there any Controller IC available for this task?
  • $\begingroup$ You might want to take a look at Motor Driver board: limited current for additional ideas. $\endgroup$ – DiaperHands Aug 29 '19 at 13:42
  • $\begingroup$ Edit your question with a datasheet. The term servo motor means entirely different things in the hobbyist market than it does in the industrial market; advise applicable to one type may let the smoke out of the other. $\endgroup$ – TimWescott Aug 29 '19 at 14:59
  • $\begingroup$ Would need more information on the servo but I would use a MOSFET. $\endgroup$ – DrBwts Aug 29 '19 at 19:45
Take a look at ARDUINO MOTOR SHIELD REV3. Here is what it looks like. If you have several motors then might have to stack several motor shields.
