I'm looking to measure and log the surface temperature of lithium ion cells (cylindrical and pouch). I tried using LM35 sensors with an Arduino, but, the drift was too much somehow. Any suggestions on how this system can be improved, as in - use different sensors or change the microcontroller?
  • $\begingroup$ Can you provide us some more details on how you mounted the sensor? Pictures would be helpful. $\endgroup$ Aug 20 '19 at 21:25
Analog can by tricky, because your signal can be distorted and the system will still work.. sort of.
I would recommend switching to a digital sensor, that way you can avoid all the analog uncertainty. The DS18B20 is popular and quite accurate.
