What is the fundamental difference between the ASCE Code and IBC Code and what is the objective of each one?
Thank you in Advance.
Sign up to join this communityWhat is the fundamental difference between the ASCE Code and IBC Code and what is the objective of each one?
Assuming you're referring to ASCE 7 Minimum Design Loads and Associated Criteria for Buildings and Other Structures, it's important to note that this document is not a code. It is a standard, published by ASCE. This standard is referenced by the International Building Code, which has legal force when adopted by a jurisdiction.
