Nuclear power always require some way of converting the energy from nuclear to electrical or mechanical to be useful. For example, in a nuclear power generation facility, this is done through heat/steam which drives mechanical generators. What is the mechanism used to convert nuclear energy to rocket power?
In Nuclear Thermal Rockets (NTRs)
the heat from a nuclear reaction replaces the chemical energy of the propellants in a chemical rocket. In an NTR, a working fluid, usually liquid hydrogen, is heated to a high temperature in a nuclear reactor and then expands through a rocket nozzle to create thrust. The external nuclear heat source theoretically allows a higher effective exhaust velocity and is expected to double or triple payload capacity compared to chemical propellants that store energy internally.
