Answer
First Part
We need to find the free stream velocity using the equation for the Reynolds Number at the trailing edge of the plate :
ReL = (Rho * U freestream * L) / mu = 10^7
where ReL = Reynolds Number at the trailing edge of the plate = 10^7
Rho = Density of air = 1.2 kg /m^3
L = length of plate from leading to trailing edge.
Note: Leading edge is the start of the plate where we measure length from
Trailing edge is the end of the plate where length is measured to
where mu = dynamic Viscosity = 1.8 * 10^-5
ReL at the end of the plate where x = L is given as 10^7
From here free stream velocity can be found as:
U freestream = (ReL * mu) / (Rho * L)
U freestream = (10^7 * 1.8 * 10^-5 kg/ms) / (1.2 kg/m^3 * 10 m)
U freestream = 15 m/s
Second Part
First of all workout if the initially laminar side changes (transitions) to turbulent at some point along the length of the plate.
To do this we will use the critical Reynolds Number given of 5 * 10^5.
we can work out x critical ( length of plate from leading edge where laminar changes to a turbulent zone )
Re critical = (Rho * U freestream * x critical) / mu
where Re critical = Critical Reynolds Number = 5 * 10^5
Rho = Density of air = 1.21 kg /m^3
x critical = length of plate from leading edge where laminar changes to a turbulent zone
where mu = dynamic Viscosity = 1.8 * 10^-5 or 0.000018 kg/ ms
Re critical * mu = (Rho * U freestream * x critical)
x critical = (Re critical * mu) / (Rho * U freestream)
x critical = (5 * 10^5 * 0.000018) / (1.2 * 15)
x critical = 0.5 m
Because the plate is 10 m long, this means that 0.5 m along the plate the flow changes from laminar to turbulent.
The next 9.5 m of the plate is turbulent.
Final Part
We will calculate the total drag force due to skin friction on one side of the plate per unit width.
As a small part of it is laminar and most of it is turbulent, this is the approach we will take for drag force.
We will treat it as if the plate is fully turbulent, then subtract the turbulent portion for x critical and then add laminar portion for x critical.
To start with we will first calculate Drag Force for the whole plate based on assuming turbulent boundary throughout the whole length of the plate.
AB = Length of plate to the transition point
AC = Length of the whole plate
(FD) for AC = Drag Force for AC
Cf = Skin Friction Coefficient
Firstly we need to calculate Skin Friction Coefficient from the formula given.
Cf = 0.074 / (Rex)^1/5
For this Rex is the Reynolds Number based on the whole length of the plate.
From before Rex = 10^7 for the whole plate.
Now we can calculate Cf
Cf = 0.074 / (10,0000,000)^1/5
Cf = 0.074 / 25.118864
so Cf for AC = 0.00294599 (assuming whole length of plate is turbulent)
Lets say (FD) for AC = Drag Force for whole length of plate AC
and A for AC = Area for whole plate covering length AC per metre span
Area of plate in AC = 10 * 1 = 10 m^2 per metre span
(FD) for AC = Cf * 0.5 * Rho * (U freestream)^2 * A for AC
(FD) for AC = 0.00294599 * 0.5 * 1.2 * 15^2 * 10
(FD) for AC = 3.9770906 Newtons ( This is Drag Force, assuming whole turbulent length of plate )
Now we will subtract the Drag Force for the turbulent part before the transition zone.
This covers the length AB of the plate.
and we will calculate:
(FD) for AB = Drag Force for AB
Firstly we need to calculate Skin Friction Coefficient Cf.
Cf is different because we are using critical Reynolds Number, which is based on critical length before transition.
From before Re critical = Critical Reynolds = 5 * 10^5
Cf = 0.074 / (Re critical)^1/5
Cf = 0.074 / (500,000)^1/5
CD = 0.074 / 13.79729661
so Cf for AB = 0.00536337 (assuming turbulent flow in critical length portion before transition)
Lets say (FD) for AB = Drag Force for assumed turbulent length before transition.
and A for AB = Area for whole plate covering length AB
Area of plate in AB = 0.5 * 1 = 0.5 m^2 per metre span
(FD) for AB = Cf * 0.5 * Rho * (U freestream)^2 * A for AB
(FD) for AB = 0.00536337 * 0.5 * 1.2 * 15^2 * 0.5
(FD) for AB = 0.362027 Newtons
( This is Drag Force, assuming turbulance in critical length portion before transition )
The actual Drag Force in Turbulent Zone = [ (FD) for AC - (FD) for AB ]
The Drag force in Turbulent zone = 3.9770906 - 0.362027 = 3.6150636 Newtons for B to C
Now we can calculate the actual force in the laminar zone.
(FD) for Laminar or (FD) for AB for Laminar Zone
For this Laminar flow CD = 1.328 / (Re critical)^1/2
CD = 1.328 / (500,000)^1/2
CD = 1.328 / 707.1067812
so CD for AB = 0.00187807561 (for actual laminar flow before transition)
Lets say (FD) for AB = Drag Force for actual laminar zone before transition.
(FD) for Laminar = CD * 0.5 * Rho * (U freestream)^2 * A for AC
(FD) for Laminar = 0.00187807561 * 0.5 * 1.2 * 15^2 * 0.5
(FD) for Laminar = 0.12677010373 Newtons
Total Drag force on plate = [ (FD) for AB of Laminar + (FD) for BC of Turbulent ]
Total Drag force on plate = 0.12677010373 + 3.6150636
so Total Drag Force due to Skin Friction on one side of the plate per unit width = 3.7418 Newtons per metre span
Book answer is 3.75 Newtons because it rounded up to the nearest 0.05 Newtons
There is another way of doing this, it involves calculating the combined Skin Friction Coefficient Cf and then calculating Drag force from that formula FD = 0.5 * Rho * (U freestream)^2 * A
for the whole plate
However I am not sure how to calculate the combined Skin friction Cf doing it this way.
Find the combined Cf Formula for the whole plate
For the laminar part of the plate, Skin Friction Coefficient (Cf) = 1.328 / Rex^1/2
For the turbulent part of the plate, Skin Friction Coefficient (Cf) = 0.074 / Rex^1/5
Now Rex = Critical Reynold Number, where the transition from laminar to turbulent happens and for this Question, Rex = 5 * 10^5
Let L = Total length of plate
l = part of L, in which boundary layer is laminar
B = Width of plate
U = Freestream velocity of air, also shown as U freestream
Lets find an expression for Drag Force on length l, when boundary layer is laminar
Drag Force on Laminar part = 1.328 / Rex^1/2 * B * l * ((Rho * U^2) / 2 )
Where Rex is critical Reynolds Number of 5* 10^5 , because it is before the transition to turbulent
Now we will work out expression for the turbulent part
For the overall length L :
Lets find an expression for Drag Force on length L, when boundary layer is turbulent
Drag Force for L, if whole plate is turbulent = 0.074 / ReL^1/5 * B * L * ((Rho * U^2) / 2 )
where ReL = 10^7 for the whole plate
Now lets find an expression for imaginary turbulent l length of the plate.
Drag Force = 0.074 / ReL^1/5 * B * l * ((Rho * U^2) / 2 )
