I read an article in a textbook which says stiffer rubber increases vibration damping and softer rubber increases vibration isolation.
Can anyone explain this how?
What is the difference between vibration damping and vibration isolation..?
Sign up to join this communityI read an article in a textbook which says stiffer rubber increases vibration damping and softer rubber increases vibration isolation.
Vibration isolators work because there is relative movement between different parts of the isolator. Softer rubber tends to create more relative movement.
Vibration damping in rubber depends on the amount of strain energy transmitted through the damper. For the same vibration amplitude, higher stiffness tends to result in increased strain energy.
Think about the extreme situation where there is no connection at all between the two components (but something magical prevents the structure falling apart). The vibration isolation is perfect, because nothing is transmitted from one component to the other, but the amount of vibration damping is zero because nothing is absorbing energy from the system.
Warning: general statements like the comment in your textbook can be misleading unless you think carefully about what is changing and what is kept constant. For example, changing the stiffness of part of the structure can change its vibration response (by change the resonant frequencies) independent of any effect on the system damping.
