My intuition on how a twist drill bit operates is that the cutting is done by the end of the drill bit and that the fluted section carries away material as it's cut.
When I look at twist drill bits, though, it appears that the edge of one of the flutes is sharpened. What purpose does this serve? Does this edge actually cut material?
