I general, if you model a system (pendulum for example) and you do not include damping into the system (maybe caused by friction): Is it generally possible to tune a PI or PID controller for an second-order-dynamical system that is undamped? Because without friction/damping no energy can leave the system, and therefore I am wondering, if PID-control can generally work for these systems or if this will lead always to oscilations or unstable control?
    $\begingroup$ The controller can take energy out of the system, if the controller "force" acts the opposite way to the "velocity". $\endgroup$ – alephzero Jul 30 '19 at 11:35
  • $\begingroup$ @alephero You are right. I didnt tought about that. But I think technically without damping, a system-model behaves like a perpetuum mobile, which make things difficult for controllers in general. But I think my question is answered. $\endgroup$ – Lemonbonbon Jul 30 '19 at 12:30
Yes, as long as the plant is controllable, observable, and doesn't vary too much from the model.
In terms of pole placement, a PID controller with a settable bandwidth on the derivative adds two poles, and has four settable parameters. The system has four poles (two from the plant, two from the PID controller), so in theory, not only can you stabilize the system, you can put those poles wherever you want.
In practice, you'd want to use a more robust design technique.
