started by designing the gear meshing, and now I need to calculate some parameters to determinate if this meshing works for me.
The system considers an electric motor, which technical parameters are: - Power supply: 220V/50 Hz - Motor power: 180W
According to what I been studying, I start by calculating the T input (no-load) of the electric motor. For a 50 Hz three-phase supply and 2 poles: T = 50(Hz) * 60 (s/min) * 2 (Neg-Pos pulse) / n° poles = 3000 RPM Considering a slip speed of 6 - 7%, I end up with 2750 RPM (no-load)
Tinput = 0.241384 (lbf.ft/min) * 5252 / 2750 = 0.46 (ft.lbf) = 0.57 Nm
Now, my question is; Which is the relation between gear ratio and RPM to find the T output? What do I need to calculate the Torque output?
I know that when the gear ratio increase, usually the rpm decreases and the torque increase.
My goal is to move a gate of 600 Kg with a speed between 18 mts/min - 20 mts/min.
