Newbie question, moderately educated on RF but only the signal, not at all about the hardware. Looking to start experimenting on a concept that would require a dynamic shift over time from one frequency to another between the transmitter and receiver. When a part is listed as, for example, a 443Mhz transmitter, is that typically the only frequency it can output at? If so, what key word would I search for on a part site to find a dynamic frequency transmitter?
I tried searching "dynamic frequency transmitter" on distributor sites such as Mouser Electronics with no apparent luck in the results.
  • $\begingroup$ Do you mean a transmitter that can smoothly slide it's carrier frequency from frequency A to frequency B over time? I'm not sure that I know of a name for such a thing, but while it has nothing to do with the name of the beast, the phrase "regulatory hurdle" does come to mind. $\endgroup$
    – TimWescott
    Jul 24, 2019 at 19:15
  • $\begingroup$ @TimWescott yeah, smoothly $\endgroup$
    – J.Todd
    Jul 24, 2019 at 23:48
  • $\begingroup$ No it is not common, AFAIK. Yes, it could be done, although you may need to do it yourself. Chances are a software-defined radio could be smoothly tuned in the manner you describe -- although it's even-steven that someone may have done something to cause it to hiccough every time you change frequency. $\endgroup$
    – TimWescott
    Jul 25, 2019 at 0:03
