Putting together a project, I've found this clutch but I've never seen this type before. It has a sort of flexible plate connecting the two parts, attached to both in two places corresponding to where the four teeth are. It seems to be working but I have no idea what torque it's ok for and how much I should compress it, if at all. Sorry for the shitty photo quality. photo of the coupling
It could either be an oldham coupling. The photo's a bit blurry. Here's a web page on oldham couplings. https://www.huco.com/products/couplings/oldham-couplings
Oldham Coupling
https://www.couplingtips.com/oldham-couplings/what-do-you-know-about-oldham-couplings/
or it could be a Flexible flange coupling
  • $\begingroup$ It's definitely not the Oldham, because it has a middel disk. But the second guess is correct. $\endgroup$ – Sam Farjamirad Jul 23 '19 at 9:32
  • $\begingroup$ See also Jaw or Spider couplings, like these: google.com/… $\endgroup$ – Catalyst Jul 23 '19 at 15:46
These drive clutches can be used to absorb drive train shocks and/or slight mis-alignments of the two shafts.
These are available in several sizes and capacities.
Flexible coupling or flexible drive coupling or flexible shaft couplings, see:
enter link description here
