Say I have a light source at a distance of 1Km from a light detector (photo detector). Right in front of the sensor, I keep a rotating reticle with some sort of pattern.
To better appreciate the situation take a look at the image below.
https://www.ausairpower.net/XIMG/reticle-abc.png
Now I want to simulate the detector output signal for various patterns on the reticle. For example "reticle B" from the above image would produce a square wave, and the "reticle A" would produce a pulse train.
Is there any tool for doing such kind of simulation? Is there any python/matlab library?
    $\begingroup$ A signal generator? $\endgroup$
    Jul 22 '19 at 17:41
  • $\begingroup$ You do realize that A and B are essentially the same, only more pulses per rotation in one. $\endgroup$
    – akauppi
    Jul 24 '19 at 13:13
