From your image, we can clearly see supports on two edges of the slab. It seems reasonable to assume this is your entire model (that is, that you haven't created a view where the rest of the structure is "hidden").
That being the case, the slab will behave entirely according to how you've defined the supports. By the slab's behavior, it seems you've defined the supports as pinned, not restricting rotations. This being the case, the slab is free to rotate around the supports and does so, such that no negative bending moment is generated.
In a real structure, however, the slab's behavior is affected by the stiffness of its supports.
Slabs are usually supported in one of two ways: either by walls or by beams (which are themselves supported by columns)1.
When slabs such as yours (which is only supported on two opposing edges) are supported by walls, the entire wall-slab-wall structure behaves like a column-beam-column frame. Just as the beam tries to deflect by rotating its supports (the tops of the columns) and the columns resist, generating negative bending moment on the beam, the walls resist the slab's rotation, generating the same negative moment.
Obviously, the columns/walls are flexible, so there is rotation at the beam/slab's edges. Just not as much as there would be if the connection were pinned.
When a slab is supported by a beam, however, is does basically behave as if it were a simple pinned support. That's because the slab rotating is felt by the beam as a rotation around it's own axis. That is, the beam feels torque (as well as bending moment from the vertical force transferred from the slab, of course). And beams are very flexible to torque, especially the types of beams commonly used in non-infrastructure construction. So the slab basically feels it can transfer its load to its support (the beam) and that it can rotate freely around that support: the very definition of a pinned support.2
That being said, there's a catch.
I've so far only discussed a single slab being supported by walls and/or beams.
But what if a wall/beam is supporting not just one slab, but two? That is, you have a slab to either side of the support.
Well, in that case, the other slab's stiffness must also be taken into consideration. Making matters worse, two side-by-side slabs will usually be designed under the same loading conditions. So if one slab under load is trying to rotate a wall/beam one way, the other slab will be trying to rotate it the other way, most likely canceling that rotation out entirely.
So if two slabs share a supporting wall or beam, they are usually treated as being fully fixed on that edge.
1 Slabs can also be directly supported by columns, but that's much less common and orders of magnitude harder to calculate.
2 There is a slight effect from the beam's vertical deflection at midspan, but it is negligible and usually ignored.
