I am working on the project of Modelling of Combustion Process of Internal Combustion Diesel Engine Using Ansys ICE Fluent, in Which I am facing problem to obtain the Desired Result.
My Objective: To plot Graph between Crank angle and Cylinder Pressure of IC Engine
Problem: The output Report which is given by the Ansys ICE Fluent after simulation does not have the correct plot.
I want to obtain the Pressure vs Crank angle plot (figure2) but the obtain report contains flow time v/s time steps plot(figure1) in place of Pressure v/s Crank angle and still, after a number of simulation and data modification the obtain report does not have the desired plot.
Figure1 (flow time v/s Time steps plot)
Figure 2 (PRESSURE V/S CRANK ANGLE)
