So, I was trying to make something like this
enter image description here.
However, While I have the motor, the motor has a vertical shaft and I need something to connect a rod to it in a T shape
Is this even possible? And if yes, then what should I get?
Yes, you could design a "top hat" that sits on the motor shaft and is secured with a couple of grub screws at 90°, with a hole for the rod to go through (the rod can also be secured with a couple of grub screws or if the rod is threaded, use a threaded hole instead).
Here's an example with a 6mm diameter motor shaft and a 6mm diameter rod:
A detailed drawing of the part in question would look something like this:
  • $\begingroup$ It may be easier to manufacture if you drill the bottom hole to the other shafts hole. $\endgroup$
    – joojaa
    Jul 2 '19 at 12:51
